AC problems
Theosophy
My trucks (2019) AC has been sub par since ive gotten it, but within the last couple years it seems to have gotten much worse. The fan doesn’t seem to blow as hard and these days, and it almost feels like the compressor doesn’t even work. I aware that the early models tend to have issues within the blender. Ive also seen the valve fix. What im really wanting know is if it is possible to actually fix the issues. Not just put a bandaid on them. Would replacing the blender actually help?
I found that I cant use a HEPA cabin filter, they are far to restrictive and the fan on 7 feels like its on 3. A dirty cabin filter would also be the same.
Does it get cold or just poor air flow?
I believe there was some kind of recall on the 2019 I had a 2500. Never had a problem with the AC but I know a lot of people did.
We can look into this for any documentation or possible routes of support. Feel free to connect with us by DM at any time.
Chris,
Ram Cares
Also, I have found that regardless of my initial setting for a/c I have to access climate control via the touch screen for MAX a/c. Just pressing the recirculation button doesn’t activate it by itself.
It was a TSB supported by temp test fail and/or "customer complains." I had my 2020 TSB completed. They rip out the dash and replace the whole HVAC box and flash the climate module.
Helped AC, driver side defrost still sucks as there's very little airflow. Tempted to run it without the cabin filter in the winter but couldn't do so in the summer it's just too dusty here and where we travel. TBH it's "dusty" here in the winter too when the snow dries up (or doesn't come) but the truck is rarely used in the winter months.
If you didn't get in on the TSB under bumper-bumper warranty I think you're hosed. Not sure if Maxcare extended warrant would cover but I doubt it. Best case one might be able to get the flash as a paid service. Not sure the flash update alone will solve anything.
On my recent cabin filter change with the HEPA FILTER I removed it and tried running the AC to see how it was with no filter and the cmimate screen flipped out and the AC would t run. Put the filter back in and worked normally. Not sure if it was a fluke thing or the 2024s won't run the AC without a filter.
