Adding factory equivalent rear air suspension?
DubVBenz
As I dig through hundreds of pre-built listings of Limiteds and Laramies, I am finding it exceedingly rare to find a 2500 with the factory air suspension. From what I understand the ride quality is vastly improved with the rear bags, so I'm wondering if it's possible to swap out the coils for a factory equivalent (or better) rear air suspension. The option itself is not that expensive, but the integration (auto leveling) is what I imagine would be the difficult part to retrofit.
Check Kelderman: https://kelderman.com/?srsltid=AfmBOoq0mcc8agEYCZdaR_RgRNiBnR7G8EYqFJWpnhDg2w6p7RM_wHGd and also Timber Grove: https://timbergroveenterprises.com/ they have different solution. I used air bags from timber grove and added airlift pump. There is also a big thread on airbags. Do a little searching in the mod area.
Thank you, I think I've just decided to ensure whichever one I buy has it standard, whether or not I have to order a custom one or not. I appreciate the links though!
air suspension kind of sucks tbh, I don't notice any ride quality changes
Interesting, do you have the factory system or did you add bags to the standard suspension? Also, 3500 or 2500, 2500 just has air in place of coils, 3500 has air in addition to leafs.
I would be very curious too, about the cost of adding OEM air ride. The reasons for me are simple, factory quality & features. I would love to have all the factory features, including alt ride height. I would like to use the bags from Logiq and factory module and compressor. @Jimmy07 is this even possible as far as the wiring and programming?
3500 HO with factory air suspension. Just loaded it down with a 3500lb truck camper and hit the air suspension. It raised it a pretty good amount but haven't driven it to compare yet. The gooseneck and 5th wheel I don't notice much difference with air.
Interesting. I haven’t been around the 3500 “air helper” setup.
My air ride 2500 rides just as cushy as my old half ton.
