Have you guys cleaned the intake heater grid area?
2500Ram
Maryland
I washed out my EGR cooler about 6 months ago and it was DISGUSTING. Cleaning the cooler helped space regeneration cycles out further apart. Now I never cleaned the actual intake over the grid heater which I assume is just as nasty. I'm just curious from the guys that have cleaned it out what gaskets they needed. I'm guessing I need a set of EGR crossover tube gaskets and an intake plate gasket and a grid heater gasket. So my thinking is I need those 4 pieces. Am I wrong? Is there a non-dealer source for these?
I'm wondering if this should be a recommended routine maintenance service?
I plan on doing it every 50-60K. It wouldn't make sense to leave it alone because you're just going to get a blocked cooler and those exhaust gasses backing up and coking up other areas. Making a total mess if you don't clean it. What a disaster but I am glad I got it. Now to do intake which was being fed by the cooler and I expect to be just as bad.
