Brake Pedal movement/excessive play
sstoner911
I had a 2015 Ram 1500 where the brake pedal developed some excessive play and the dealership replaced it under warranty and it resolved the issue.
My 2024 Ram has developed a similar issue and the brake pedal is rattling at times on bumpy dirt roads etc...
So today I took it in to the dealer and had them look at it(along with a noise in the steering shaft and radio bezel). So after 5 hours the tech came back and said the movement in the brake pedal was consistent with other trucks on the lot. Which I do not buy, as this problem has been getting worse over time and I was waiting for it to be bad enough for the dealership to be able to duplicate it.
So does you Ram brake pedal have this much play?
My '22 had that exact same amount of play and made noises on bumpy roads, was terrible I even got to a point where I used my left foot to hold it up on long gravel road drives. New '25 doesn't (yet) with 4k miles on it but from your experience sounds like it likely will in time :| I'll have to go manually check how much play the new truck has now and monitor it.
I am raising this one back up...'25 Power Wagon and this just started happening at 5k miles. WTH???? Had a 5th gen 1500 prior to this and no problems, 2nd gen 2500 prior to that and no problems...seems like things are just going down hill (hope i won't be with this brake issue either)! Anyone else dealing with this????
I don't have that much slop in my brake pedal but it does squeak when pressed if the interior cab temp is cold. When it warms up inside, it stops.
I literally grabbed the brake pedal and the whole assembly is loose! Will see if I can post a video later (very similar to the OP here) but could but could not believe it.
I have an appointment Friday with the dealer. There are plastic bushings on the arm that hold the brake pedal on. I am thinking those are bad. Number 3 in the diagram. Mine is worse now than when i filmed that video.
Went to the dealer today to have mine looked at and was told that it’s normal. We looked at other 2500s on the lot and they too have the same play in the brake pedal. Was told that it’s primarily due to them being adjustable. So moved them as far back as possible and it helped a little but it still jostles over bumps. So that’s where I am with it. Even the service adv was like, it’s just a crap design.
Went to the dealer today to have mine looked at and was told that it’s normal. We looked at other 2500s on the lot and they too seems to have the same play in brake pedal. Was told that it’s primarily due to them being adjustable. So moved them as far back as possible and it helped a little but it still jostles over bumps. So that’s where I am with it. Even the service adv was like, it’s just a crap design.
I have an appointment on 04/03/2026 to have the brake pedal assembly replaced. I imagine you will have to wait for it to become excessive before they deal with it. I dont have adjustable pedals.
