Toyo Open Country RT Pro tires
buck79
East Tennessee
Just wanted to throw this up here. Had a set of the new RT Pros mounted and balanced today for my 2020 Power Wagon. All stock suspension minus the Bilstein 5160's all around. The wheels they are mounted on are Method MR315 +25 offset. Tires are a 37x12.50R17. Initial impression is I like them. It is raining here today, and they are about as good as the worn 25K mile RT Trails they replaced. So "OK" in the wet so far. The ride comfort is excellent. I am currently running the fronts at 43 psi cold and the rears at 34 psi cold. You can tell they are a heavy tire. I weighed one tire here on a digital scale and got 84.6 lbs. They balanced with about 4-5 oz per tire. Run silky smooth down the highway. No weird vibrations or anything to speak of. They are a much more aggressive tire than the Trails, and I liked the Trails well enough off-road, so I will assume they should be superior to them in that environment. Love the look of them. Great sidewall. So with less than 100 miles on them, I can say I'm happy. One thing I will say is they run closer to 37 inches at 36.8 inflated, where the Trails were advertised at 36.5. I had no rub with the Trails after a few thousand miles, and with these tires I had to remove the little mud guards behind the front wheels, and actually looks like Ill go ahead and do the trimming that I should have done in the first place. The rub after removing those guards is very minimal. I could live with it until these wore a little if I was so inclined and stayed on the street.
I feel like the trails are kind of noisy compared to the AT3’s
I guess I should have thrown road noise in there too. I thought the Trails were a quiet tire, until they wore down a bit. Still could have a conversation in the cab with the windows up no problem. The Pros start out a little more noisy than the trails, but I don't notice unless I have the radio off and am listening for it. That AT3 is going to be the quietest out of the three for sure, but I have no noise complaints with the other two.
According to the Toyo Open Country website their AT3 is rated 4.0 out of 5 on quiet. The R/T, R/T Pro, and R/T Trail are all 3.5. The M/T and C/T are much heavier tires and are rated 3.0. I run C/T on both of our Ram HD trucks.
What was that you said? Can't hear you.
The trails aren’t too bad.
Barely noticeable over the drone I experience with my Neighbor Hater muffler.
I'm in a debate over these the RT Trails or the Nitto Ridge Grapplers, do you find that these look any narrower than the RT Trails or about the same? I've read from other people commenting that the appearance looks narrower than a RT Trail or Ridge Grappler, this is the only thing keeping me from buying these. The sidewall looks awesome! Thanks!
Does your truck ever see rain (or snow)? If so, run, don't walk away from Nitto Ridge Grapplers. A lot of guys call them ****to Ridge Crapplers because they will try to kill a fella' on a rainy afternoon. I'm not sure how those tires became so popular. They are pretty miserable in all categories, including price.
Rain not snow I live in Louisiana so normally we see quite a bit of rain. I think I've eliminated the Ridge Grapplers at this point and I'm down to the Open Country RT Trail or the RT Trail Pro.
