Overall, I feel Dave had more positive comments than negative comments as it relates to the new 2025 Cummins engine.
People have been saying the head/valves/rocker arms/lifters, etc on the 2025 are the SAME as the 2019-2024 models--Dave proved there are differences--prayerfully these differences are going to result in a more solid platform (especially when Ram gets the "electrical" issues resolved).
The video kept "buffering" for me, so it was difficult to watch.
The flat tappet engines cams had the same number of bearing journals, but they had no bearing inserts, the cam journals rode directly on the block except for the end journals, I believe the old 5.9's only had a bearing on the gear end.Did I hear it right? My hearing is pretty bad. Earlier engines only had a camshaft bearing at each end?? I may have misinterpreted the video, but found it hard to believe that the camshaft would not have more bearing support than that. Of course it has been almost 60 years since I was in the trade and things have changed. LOL. The 2025/6 now has a bearing between each cylinder??
Those grooves around the upper neck of the lifter body are not oil related. They are tooling marks intentionally placed there to identify which manufacturer (or specifically which production line) each lifter body was manufactured by. There are, or at least were, up to 5 different “versions” of the lifter body at one point. Pretty sure that’s been narrowed down to just a few now. It isn’t uncommon to pull all 12 lifters out of a factory engine and find a mix’n match set from different suppliers.I saw that they did not have any oil control(?) grooves cut in them.
mbarber84,Those grooves around the upper neck of the lifter body are not oil related. They are tooling marks intentionally placed there to identify which manufacturer (or specifically which production line) each lifter body was manufactured by. There are, or at least were, up to 5 different “versions” of the lifter body at one point. Pretty sure that’s been narrowed down to just a few now. It isn’t uncommon to pull all 12 lifters out of a factory engine and find a mix’n match set from different suppliers.
Some suppliers have a higher failure rate than others, depending on when they were manufactured.
The same supplier that manufactured the lifter bodies for 24 and older, are still supplying lifter bodies for the newer engines 25+.
They did, however, change the manufacturer for the roller that attaches to the lifter body.
That’s a reality that becomes more and more clear to me each day!Right, and I now remember seeing that info. The (elderly) mind is a terrible thing to waste.![]()
Both the lifter bodies and the rollers that attach to them can cause premature lifter failure.mbarber84,
Good info--thanks.
This sentence caught my attention: "They did, however, change the manufacturer for the roller that attaches to the lifter body."
Do you have any more details on this?
Oh it’s definitely a given.You'd think the fact that lifter rollers need to be round and not tapered, and that the roller needs to run perfectly parallel to the camshaft would be a given. If deficiencies in these areas are what was causing lifter/cam failure then it sounds like they had a design/tolerance/quality issue?
Good discussion guys...Oh it’s definitely a given.
These were 100% quality control / manufacturing issues. Not design issues.
Fretting and the block “flexing” has been noted in the past, especially by several well known performance houses, including Choate.Good discussion guys...
In addition to the quality control/manufacturing issues, I think you have to add Brutal Ho comment "I think there's merit to the theory proffered by many including Dave that the CGI block has too much flex and the lifters are "fretting" due to this."
To summarize--when you consider the of roller/roller axle bore quality control/manufacturing issues AND potentially "CGI block flex" (I say potentially because this is probably theory) you have a bad combination. Again, hopefully by Ram/Cummins changing Lifter/Roller suppliers and switching to a Cast Iron block--hopefully these problems are resolved or minimized. Feel free to step in and correct me or add to my thinking here....
mbarber84,Fretting and the block “flexing” has been noted in the past, especially by several well known performance houses, including Choate.
This video (Click Here For YouTube Video) is a good one to watch. The guys from Choate discuss this starting at the 50:00 min mark onward.
