Just installed a monster Ram still have intake heater issue
saboken
I was hoping getting rid of the factory Grid heater by installing a monster Ram would fix it. I'm still getting a code P2609 (Intake Air Heater System Performance) r, the remote start shuts the truck off about 30 seconds after starting. I haven't replaced the Grid heater solenoid yet but if I do and if doesn't fix it what should I look at next? It has 2 new interstate batteries no other codes. The old heater was really caked but the bolt was not loose. Photos attached of old heater 2012 Ram 2500 HD HO Laramie
Banks intake was your first mistake. Better and less expensive options out there. You “fixed” a problem that didn’t exist. As for the remote start issue, stop using it.
Why are these groups full of trolls? I ask a question and get opinions that have nothing to do with the question, you have a pavement princess? IDK but if you do stop driving it!
You created your own problems.
Hey brother, sorry you are having those problems. I would think replacing the grid heater solenoid would fix the problem, wouldn’t you?
That's my next step i just have a feeling it's something else. I'll see after I replace it. I'm going to check voltage going in and out of it, and the resistance between it and the battery.
Your probably right I tested the voltage I'm getting only 6-7 volts coming out of the relay it's next on my to do .
The relay is far more common than the element itself.
Are you tuned at all?
Not yet that's a project for the future, the intake upgrade was just insurance against that bolt that could fall off and nuke the engine.
It’s not uncommon to get a CEL with just the intake horn upgrade, but tuning would fix that if you get it.
I don't have a cel just a stored code that I can't erase, I broke the Exhaust Backpressure (EBP) Sensor when installing the EGR cross over pipe, it set. Code in the PCM the cel is off now but that code is still coming up in my Innova 5160RS I won't erase, I'm hoping it goes away on its own later And not a code the dealership needs to erase? It was easy to replace just a little pricey for what it is.
The group isn’t full of trolls. That one in particular just likes to act out occasionally.
I’d wager the relay is your problem.
