2025 headlight adjustment?
Slutzk
AZ
Im sitting here on google, youtube, and forums and cant find a single post, thread, video or image on where to adjust the headlights for a 2025. For the first time since I bought the truck last July I drove at night and realized I was blinding everyone so want to adjust them down and cant seem to find where to adjust them. Dont have my truck rn as im at work and when I did look at the river this past weekend I couldnt see any where like screws or arrows on the frame like a 1500. Also didnt have the time to take things apart or look little closer (and it was daylight by then.... no i dont drive my truck much, just hit 2k miles and doing a oil change barley when I get home tonight)
Any help is appreciated so i can get straight to it when i get home. photos, videos or a link would help. Thanks.
There are no adjustments to my knowledge. Your truck is leveled so you're just going to blind people. I've had the same issue time to time in my PW.
I need to dig into this as well, my 3500 with 2000lb camper is very slightly nose low but I can see my low beams are higher than they should be especially in falling snow
I just checked my 25 since mine are pretty high after level. The same white philips screw knob is there behind the headlights for adjustment. Driver side is easiest to see, then you can find passenger once you know what it looks like.
Good to know. I just changed the oil and completely forgot to check although I did it in the middle of the day and I didn't even uncover the truck completely. All I did was turn it on to heat oil up then turned it back off so. Havnt driven it in like 6 weeks since then. Ill turn it back on to actually drive it on the 21st of this month and check then. Thank you.
It takes a good bit. Probably 2 full turns of the screwdriver to bring it down after leveling. Clockwise is down.
