My 2025 Ram 3500 uses latch #6828 0337 A1.
Photo attached with my installed pull rods, passenger side configuration. Driver side you can push where I am pointing.
Thank you in advance!!That photo is not at all like my latch. I will try to post a photo tomorrow.
I do not think they operate on 12 volts. Tried to open gate by applying power to connector and ended up frying both latches. Had to purchase new replacements. $92 each.
Just how are you to open or remove the tonneau if the gate is closed?NOTE:
The optional Tri-Fold Tonneau Cover may prevent electronic tailgate release. The Tonneau Cover must be removed or folded up before releasing the tailgate.
If you have a cover of some sort over the bed, how would you gain access to the inner workings of the tailgate to manually release?
That top plug is where I applied 12v from a battery to get it to open - positive on one side and negative to the other.Yes, a stupid design. Now you go me worried, arrgghh. I did check mine, and sure enough if I lock it with the key fob, the signal is getting thru even though I disconnected what I though was the simple two conductor connector. The white round connector in your photo and X in mine is the camera connection. So the connection for the tailgate electrical latch must be the one I circled. View attachment 87709
Yep, behind the access panel, that's where I went as well.On my 2024 when I went to flat bed, a guy wanted to buy my tailgate. The only way I got it to release was to take a battery and connect a neg and positive wire to the plug for the tailgate handle.
