I want to install digital camera to a 2026 Ram 2500
sslazio
Hey I have a 2026 Ram 2500 rebel 6.7 Cummins with 360 camera view and collision warning. Unfortunately it didn’t come with a digital camera. I added it on my 22 Ram 3500 limited. I have been emailing mopar parts on what mirror I need and Chmsl. I think the mirror I need is 68654265AA and for the Chmsl is 68614663AA. Chmsl I am not sure. The cable I get from Amazon. Can anyone confirm these are right parts? Has anyone added a digital mirror to a 25 and newer and got it to work. Could the dealership get the mirror to work? I really miss having it. If not Is there any good aftermarket digital mirrors that will work with a 2026 Ram? Thanks for the help.
I am trying to do the same thing. it takes the camera processor P68508050AD and wire harness that The game or Skuppy069 can sell. part numbers look correct, but they may be able to confirm. Jimmy07 may be of some help if you can get him to respond to you. I have had no luck yet. my truck is basic with no extras; you might have different success with the options you have. good luck.
Hey. Where would the wire harness connect to beside the camera processor? Not knowledgeable when it comes to these things unfortunately.
If its anything like my 2024, the cable runs from the camera in the 3rd brake light(you will need that part as well) straight to the mirror. I bought it from Infotainment, plug and play.
I also have 360 cameras. You usually need AlfaOBD to make your dimming mirrors work after this upgrade....but that's not happening wit the 2025+. Not sure what other features you might lose with this upgrade on the 2026 trucks...but @Jimmy07 can tell you if there any major cons.
The brake light you have only has the cargo cam....the digital mirror has a second camera in the brake light - 68551077AB
Hey. Unfortunately it wont’t be plug and play for 25+ trucks. Have to get a camera module that goes under the front seat also. I added the digital mirror in my 22 Ram 3500 limited that was plug and play. Easy to install. I wish it was plug play for 25+ rams.
That module will need programming most likely....not sure how that would be done unless a dealer is willing to do it.
Live in Toronto Canada. Dealers never help out.
I think on my 2024 the only cameras going through the module under the seat is the 360 cameras. Did that change in the 2025+?
On my 2024 Ram 3500 limited I didn’t even remember seeing a module under the seat when I used to vacuum. Same with my 22 3500 limited. Maybe a 25+ thing. No idea.
I don't have one under my Seat on my Laramie, if its like my friends TRX its in the lower A pillar...then only camera that doesn't use it is the digital mirror.
I don’t know. I just read that for 25+ you need the module it get the digital camera to work. Not plug and play anymore.
