@Pressure_welder
No engine, gas or diesel “likes” idle time.
It’s harmful to both. The only difference is, the diesels have the compounded issue of the emissions / aftertreatment system which compounds the problem.
You can own a modern diesel and have no issues provided your operating habits are amended from what they were when you owned your older non-emissions engines. New generation emissions diesels need:
- Regular towing / hauling, or longer distance trips per month to keep emissions happy
- Idle time kept to an absolute minimum.
Shut. It. Off.
- Clean fuel, regular oil and filter changes based on how the truck is used
- Minimize short trips As much as possible
- Monitor emission system performance and learn how the system is supposed to function so that you can make better decisions on how to drive it, when to drive it, and what to look for when the emissions system starts showing signs of possible malfunctions.
- A thorough understanding of the emissions system and how it works (or is intended to work)
If your daily drive cycles are such that you do a ton of short trips, and don’t need to tow exceedingly heavy loads regularly, a 6.4 gas truck will likely be more fitting in your application and far less headaches.
If you require the pulling power that the Cummins brings to the table, then you have to concede that it can’t be used in the same manner that your old non emissions diesel was used. They don’t tolerate the same types of drive / duty cycles without having headaches.
I hope the body is included in that $130,000 quote for a new one, otherwise that would be one substantially expensive cab & chassis. Do you need the cab & chassis for bed / payload?
