Interesting that the 3-minute note is in some model year manuals and not others.
I drive it frequently spring through fall. Somewhat parked in the winter months otherwise with how much road salt is used in MN I would have a diesel engine with no truck body/frame. In the winter I will run it periodically, every 1 to 2 weeks, usually picking and choosing when roads are clear. Right now, I have just over 52,000 miles and 1348 engine hours. Idle hours are at 214, so about 16%. Have about 20,000 towing miles. Seems like much less than 15% - 16% idle time would be hard to achieve since Cummins also recommends 5 minutes of cool down time after heavy towing.
Another part of my reasoning for warmup has nothing to do with the heater cycle but rather engine temp in general. This comes from my work background of designing and testing cooling systems for industrial diesel engines. Primarily for the mining and oil/gas industries. Whenever we would test the cooling system on the equipment the engine manufacturer would insist on a warmup period and generally a stepped approach to reaching full horsepower. This was consistent whether it was Cummins, Detroit Diesel, CAT or MTU. At some point Cummins established a minimum ambient temperature for testing, I think 70F, so coolant temps weren't too low during full power.
I have read and heard good things about the NOCO product. Right now, I have an Optimate5 charger/tender and a John Deere branded tender - not sure who makes it for them (my wife worked at JD dealer briefly).
What battery make do you prefer? I have had good luck with Interstate in other vehicles, campers and boats.
