2019 2500 Extra Key FOBs
mdsonofthesouth
I have OBD+ and AlphaOBD that worked great at programming keys and so much more for my 2016 ram 1500. Wondering if the 2019 uses a new security system that Alphaobd can work with, or if I can continue to use this setup.
Jscan can do the fobs you need the security bypass cable though for the 18+ trucks
You will need JScan and a security bypass cable for the 19+ trucks to program FOB. You can use AlfaOBD (and the bypass cable) for most everything else.
Dang I read somewhere that the paid AlphaOBD could pull the code...or that Jscan pulled the code and alpha programs the fob. So much conflicting info out there I had to ask. I have 2 fobs coming since the truck only came with one. Guess Ill need to invest in Jscan and a cable....
NO.
That is a cable for a 1500.
You'd have to pull the dash to use that. NOT recommended.
Use the links I provided.
Deleted. Hate to send the wrong message.
I see the cables are setup for permanent install. Not sure Id keep it it. Make the changes I want and program the keys then take it out. Just dont see a reason to keep it in unless you plan to change alot of settings with alpha or scan.
Either way thanks for the help, looking to grab a cable and setup a jscan license here today.
