Is this a normal amount of transmission leak?
Olbc
This is a 2024 ram 2500 rebel HD Cummins. Leak is coming from where 68rfe connects to the motor I think. Here is a pic
Based on the location, don’t think that is transmission fluid. Also that doesn’t appear to be a true leak…maybe some seepage. that’s coming from the bell housing so makes me wonder if it’s rear main or something.
You’re right it’s the bell housing. I thought that still “counted” as trans
Rear main?
Take the inspection cover off and have a look. Posting a photo here might be beneficial to someone else here too. If it persists, put some dye in the oil.
I'm not even sure that is worth it. Most dealerships would look at that and consider it not a leak and would not look at it under warranty.
This.
wash it off and drive it for a while and see what it looks like and go from there.
Most all of my Ram Cummins have seeped like that when new. Clean it off and keep an eye on it but more than likely main seal assembly lube
Hello, @Olbc!
Know our team is available should you like to troubleshoot further or elect to visit your nearest dealership. Feel free to send us a private message!
Hannah
Ram Cares
Hello, @Olbc!
Hannah
Ram Cares
Thanks Hannah! Good to see you guys are around!
