2019-2020 HD damper strut- 68362518AA
I don't get it. I went to like every single website that sells mopar parts and when I entered the vin or by model and year they never showed up. I have been looking for two days. What am I doing wrong?
Lots of 2020 parts don't show up or only show one model and not the other. If you can't find something that should be the same 2019+, try 2019.
Well, I ordered a key today. I will see the dealer to get the new key activated, and to get the codes for remote start activated. If they will only do the key, it may provide enough incentive to purchase the stuff to use AlphaODB.
About the FOB. Right now I have two original ones with close . open and panic button. Since I want to add remote starter and tailgate assistance I purchased one with corresponding buttons. My question is...can I go to the dealer and asked them to activate it right now before I install remote start? And once I install it activated it with AlfOBD? Everything should work?
It is my understanding, that the facilities for the remote start are already present. But without a fob button to activate it, and the feature codes active, it doesn't work. The dealer supposedly has the ability to turn on the codes when they activate the new fob.
What do you think needs to be installed?
Ive ordered the MXODBII module, and the bypass cable. When those arrive, I'll purchase the AlphaODB.
In my truck I need to install a hood latch with sensor. Other member said you can go around that if you install a resistor somewhere to make the computer think hood is always closed
Shhhh...I already have a sensor there that is wired in. If I am looking at the correct object, it is attached to my hood latch.
Where would I go about finding the hood latch sensor? anyone have a part number? I know I don't have one on my Tradesman. I already have AlfaOBD and have used it for TPMS. So it seems I just need the FOB (and get it programmed) and the sensor. Right?
To add to my reply above: another option if you don’t have the hood latch and wiring- the hood ajar sensor wire is most likely present at the BCM connector C1 pin 11. You can just ground that wire with a 1k ohm resistor, and the BCM will see the hood as always being closed. Just throwing that out there if one weren’t concerned about installing the correct latch and wiring.
I might have to go that way cause I can't find a way to get thru the engine wall. Have no idea how to run the wires.
You just go through the plastic round clutch delete plate.
This is how much room I have there
The Aux PDC pulls out some.
I tried to pull it out and it slides out maybe 1/16 and that is. I don't want to damage the clips. Unless I'm doing something wrong
Okay I ordered the firewall boot and ran both wires. Now I'm stock at the pin 11. How I suppose to fit my hand in there?
I think you have to loose the two bolts visible there between the Aux PDC and the battery tray?
You may need to loose the AUX plugs from the PDC as well.
I pulled mine out once, but I've slept since then.
I was able to just slide both plugs out. They have separate attachments on them. But now I'm stuck on the pin 11. I have to get all the way back to BCM to connect the wire there. REALLY tight space.
If you have the amplifier or active noise canceling module mounted next to the parking brake, remove it. The full wire bundle for the BCM connectors is attached to the center of the BCM with a zip tie push pin. Pry that out so you have more slack to work the connector. It’s the top left connector (black) you are inserting the wire into, but just unplug all of the connectors from the BCM for more slack. To release the ones with the lever locks, put your index finger above the lever to push in the release tab while prying up with your thumb on the bottom of the lever. Slide the black curved wire hood off of the connector. If there is a wire in pin 11 already, just remove it and install the new wire.
