Trailer 360 Camera
jgholt
I have a 2024 Ram 2500 with the Trailer 360 option. Ive had issues since this unit was installed for a couple of reasons. The real problem now is that the 12 pin connector thats connects from the trailer to the truck has pulled out and the wires are broken away from the pins internal to the connector. Can anyone advise me as to the wire to pin layout for the connector? im having no luck!
Thanks so much for this info. Will check it out asap. I have 7 wires, the diagram you offered has 8.
Sorry about that, incorrectly posted the Ford connector on that first reply (removed).
Pin 2, 3 are the CAN BH for the surround, but I don't have the wire colors handy. And I don't have the trailer side info.
Thanks for the reply. The wire colors to pin assignment is what im looking for. It's good to know that at least some data is out there so I wont give up hope just yet. Im trying to buy the cable separately but Ram says I have to replace the entire system at around $2200. This is absurd im thinking
@Jimmy07 had a link up to a google doc with the wiring, but it's aged out. Maybe if he sees this, he can repost (and this time I'll capture it).
Thanks again for your help. I'm getting close to the end of the rope on this Trailer 360 Camera issue with the trailer side plug connector becoming separated from the wires. Im hoping someon can provide the wire color to the correct pin on the plug. see attached photos which may help. Any advice would be helpful.. Hoping this catches the right person.IMG_8472.jpegIMG_8814.jpegIMG_8815.jpeg
