Next project is some splash shields. First off, I needed to extend the front part of the passenger wheel well so it stops slinging mud forward. Here's the pieces mocked up after a bunch of bending, cutting, and guessing.
Next, MIG welded up the joints in the bent angle piece and then ground them down smooth-ish.
Looking pretty good..
To attach it to the tire carrier I used some special closed end rivnuts. These were installed with a dab of sikaflex so they are as water tight as I can manage.
I originally planned to do a second set of rivnuts from the back side as well and drilled the splash guard for it, but it is so stiff as-is I decided to not bother. When the pieces are fully installed after powder coat I'll be adding plenty of sikaflex so it's not going anywhere.
Part two of this project is to add some splash guards to prevent the road spray and crud from piling up on top of the storage boxes as there's a little pocket there. I cut out 3 of these panels on the CNC plasma.
Installed they look like this. Only one needed on the rear passenger side, but the driver's side gets them front and back since there are two boxes over there.
It tucks right up into the bottom of the bed extrusions. Should do the job.
Finished pics with the outer dual back on.
Pretty pleased with that. All of this stuff will come off in December most likely to get the boxes and these splash guards powder coated just for some corrosion protection.
Supposedly our new camper was built this week so we may be seeing it very soon...
