hobbyguyshawn
I've mounted a plow to the front of my '24 3500. She's a SRW with the 6.7 HO and Auto Level Rear Suspension.
I knew that I was going to have to add ballast weight to the bed but what I seem to have completely over looked is the Auto Level in the rear. I've added almost 1,400 lbs to the bed and not a single pound has shifted away from the front axle. The rear axle and total vehicle are obviously heavier, but the auto level just jacks the bed back up and keeps the weight on the front.
I haven't done weights with the ballast installed and the plow off to see how those numbers change from before the plow installed, but something tells me I will find the same results with no weight transfer happening.
Has anyone been here before, and if so, how did you manage to get the weight off the front axle?
