NO LONGER AVAILABLE: Looking for a Part Number? Must provide VIN (only up to model year 2020 at this time)
Status
Not open for further replies.
68367432AC is specific to the cab chassis, with sales codes:
GU3 (BLACK/POWER/HEATED/SIGNAL/PUDDLE/RUNNING LIGHTS/TRAILER SPOTTER)
XAK (SURROUND VIEW CAMERA SYSTEM), and
LFX (CONVEX AUX MIRRORS, POWER-ADJUSTABLE).
68361478AC is for the 2500/3500 (D2/DJ), with sales codes:
GPH (POWER BLACK TRAILER TOW MIRRORS - NIGHT EDITION),
XAN (BLIND SPOT AND CROSS PATH DETECTION), and
XAK (SURROUND VIEW CAMERA SYSTEM).
Hope this helps.
thank you so much!!
#12 was filtered out when I used the VIN and #24 says non-serviceable part...attached is the full parts list for the illustration. Hope it's helpful.
It does fit with what I have found so far... so weird. basically I will have to go to dealer parts and try to figure this out.
Thank you!
hi, looking for the driver side front seat belt for VIN 3C63R3RL1LG215587 or 3C63RRJLXLG158496 and if different, could you let me know the difference? thx.
Hello. I'm looking for a the lower portion of the sliding bin for a Limited/Longhorn. I found this VIN for a 2020 Limited. Let me know if you can help. Thanks!
3C6UR5SL9LG212835
Need this part. There are 2 different bin styles. One for the TM up to Laramie and the other is for the Limited & LH Limited Trims. I definitely need the Limited/LH lower sliding bin. I'm swapping out my bins in my Laramie for the Limited's. I'll PM you as well.
Sorry, for some reason I stopped getting notifications again...here ya go. They appear to be the same...see attached.
3C6UR5SL9LG212835
I'm not finding that exact diagram, but checkout the attached file...I'm thinking it might be #40 unless I am looking in the wrong spot?
Yes, #40 is the lower part of the cup holder bin.
No problem. I thought about DMing you because I thought I saw you say something in the thread about not getting notified lol. Sorry to keep bothering you for part numbers. They don’t make it easy to tell what the correct item is!!
Ok, another request. For vin 3c63r3el5lg102831. What is the part number for the section of wiring harness that goes to the cab lights and review mirror? Thanks!
If I don't respond within a day or so, send me a DM...I might be busy not able to check something or I might not have gotten a notification.
I think this is it...
Yes, much appreciated! I believe that part number will work for what I'm looking for!
Hello, im looking for the fog light wiring harness for my truck 3C6UR5CL5KG598120. If you could help me that would be great.
Not 100% sure, but I'm thinking it's going to be one of these...
Status
