Integral Trucks Rail Kit
What are you trying to secure in the bed? For a fraction of the cost you could just run chain down each side?
This would annoy me, as my Gooseneck trailer 7-pin plug in the bed would be obstructed.
I’m running the hi lift slide and lock that mounts on the lip of the bedside, so it doesn’t interfere with any bed space. This is the second truck I’ve had it in and it’s super handy. I’ve actually made a couple other mounts to use in it when needed.
It’s also a lot cheaper option. They also make a shorter version 68” I think which is what I have it runs right up to my toolbox.
93” slide and lock
Mine is mounted a little different to make it work with my roll up tonneau cover, but it works great
93” slide and lock
Been thinking about installing something like that. I assume it’s light duty just for securing lightweight items ?
I had that same rail system in my last truck, I didn't install it, came with the truck (bought it used). I really liked it, very low profile and adjustable. I never reefed on them too hard, but certainly used some light duty ratchet straps and a ton of bungees, never had any issue with them. I think they are stronger than they initially look. I've thought about adding them to my Ram but think they will interfere with my factory fold tonneau clamps.
I can’t find a weight rating on them on their website. I’ve used mine to secure just about anything I’ve put in the bed of my truck without issue. They do bolt to the bedsides about every 10” which does help distribute the load.
