Looking for pics - 2500 Thuren 1" front & OEM rear air suspension
MegaCabn
Temecula, CA
I have a '24 2500 6.7 w/ factory rear air suspension. I'm looking to see if I can find some pictures of the same truck with the Thuren 1" front coils and stock height rear air suspension. I want to bring the front up just a little bit to get it level with the back. Even though I'm already pretty close to level now, The slight rake in the back drives me nuts!
I might just pull the trigger and order them and see how it goes. I can always get the adjustable sensor rods if it sits too nose high, but I'd rather not lift the back with the air and get an even stiffer ride.
Just get the adjustable links from Thuren. My 2018 came with a front leveling kit and rear air, I raised the rear with Thuren links, added longer Fox shocks and was super happy. There was no noticeable change in the drive.
Yeah, that's probably what I'll end up doing.
I'm looking at options for my front end. I saw one Youtube dude that said the rear air suspension doesn't play well with some front leveling solutions.
I'm about to ping Carli and CJC off-road to find out if thats true. .
I was hoping more guys would chine in here.....but there seems to be good info on another thread below
My 21 2500 had the thuren 1" coils and rear air. No issues. Factory tires in these photos. Later 295 65 with slight rubbing at full lock.
My 22 and 24 3500 with rear air also didnt have issues. Different air setup I know but no issues.IMG_20251028_195849.jpg
I have not heard about people having issues, but I was hoping I'd get a little more info here, too. From what I've seen so far, I'll probably end up going with 2" in the front. IF it sits nose high, I'll bring the back up and live with it.
I can not find a pic on my phone but here is what my air ride looks like when the rear is at factory ht, and the front has 1 inch thuren coil..
I have also raised the rear as I added extra air bags and needed the space, but this is alt ride which is the old normal, air ride so trailer hooked does not change ht. 295/65r20's
Not sure this helps but here is mine, a Thuren 2" level kit. Yes it is almost perfectly leveled. To the eye, it is, to a measuring tape im sure the rake is be an inch or less.
1" Thuren coils and sway bar with factory rear springs, tires 285/65R20 on stock wheels. However I didn't get 1" of lift, I actually got 1.5" of lift go figure. 30K later and it's still 1.5". Slight rake which I like, not a fan of the leveled look, and it's level when towing the trailer.
