Razzman
I installed a dual dash cam setup recently. I used a Dongar Technologies usb splitter in the mirror cover, routed up to the headliner and tucked it in over to the driver side pillar. Removed the pillar cover and tucked behind the wiring bundle ensuring it didn't impede the airbag in any way. Pulled down the rubber seal over to the side pillar and routed behind the headliner again to the side pillar, and tucked the cable over the top of the pillar to the rear window. Pulled down the rubber seal and repeated to the back window. At this point I realized I had way more cable than needed so I bundled the excess and tucked it behind the rear corner cover and routed behind the headliner again to the camera. Replaced all seals and pillar covers and done.Installed two of the three dash cameras (front facing and interior facing). I had all three including the back facing on my 2022 Ram 1500 Laramie I traded off a couple weeks ago. I need to research a little more on the best way to route the rear facing camera cable. I tapped into constant power and switched put in the overhead light console.
Viofo A229 Plus 3-channel
