Your front end weight will be more than my 2024 6.4 Hemi Crew Cab 4x4 6’-4” bed truck but my 2 cents is this:
From the dealer my truck rode like a cement truck. Hoping to come as close as possible to the rise of my previous 2016 Ram 1500 crew cab 4x4, I’ve done the following and am satisfied with the results:
Thuren +2” front springs, +1” soft rear springs, front sway bar, front & rear track bar, front track bar bracket, rear LCS Boogie Bump stops.
I tried the Fox 2.0 shocks but replaced them with Rancho 9000’s to get a more compliant ride.
Expensive for sure, but it’s changed me for cursing my truck to liking it.
The LCS bumps stops can be changed in less than a minute, allowing me to take advantage of a big gap between the bump pad and axle when unloaded and then utilize the taller bump stop to supplement the soft rear springs when loaded. If pulled a 13K loaded dump trailer using. WD hitch with satisfactory results.
Hope this helps.
