Looks like the Superstitions near Gold Canyon
Very nice, I wish they made a long bed version.Installed an OVS truck cap. More room for activities! Impressed with the quality so far.
On the actual radio? I messed with it several times and I didn't find a way of turning it off.That's a setting on the 24 in infotainment
No, I'm wrong. The only radio setting, is to illuminate the honks when doors are locked, sorry.On the actual radio? I messed with it several times and I didn't find a way of turning it off.
19s don’t do itWhen did they start doing this? Mine is a '19 and never did have this feature.
Last weekend I started my undercoating process. Only the bed/rear wheel wells are coated so far. I’m going to try to start the front half this weekend. I took the plastic rockers pieces off the bed so I could coat the paint they hide and make a good seal with the inside of the bed at the bottom. I did this with my wife’s grand caravan 7 years ago and it seems to be holding up well.View attachment 89894View attachment 89895
I've been using Rustoleum professional rubberized undercoating. It seems to dry and wash off well. If you knick it it'll come off, but easy to touch up. I usually reapply every 2 to 3 years to keep it built up. I plan on using either fluid film or amsoil metal protector inside the frame, rockers and maybe bottoms of the doors. I saw a video that showed the amsoil metal protector dries better and seems to last a bit longer. I do like how fluid film has a wand for getting into things like the frame though.Nice job. What are you using for fluid and gun? I’d love to do this myself. I’ve previously paid a guy annually.
Sent from me
I dont mind your stock rims at all but Longhorn Rims look almost identical to my 24 GMC SLT 2500Swapped out my stock 18" plain Jane aluminum wheels for some Longhorn wheels. Same diameter, bolt pattern, offset, etc...
It looks much better, IMHO.
Here are the original OEM wheels:
Here are the Longhorn wheels:
What spray gun do you use?
Mtm foam cannon on a little Ryobi electric pressure washer.What spray gun do you use?
