56ram2500
I have doubts the dealer will turn off the seat belt chime being its a safety thing just like they are not allowed to change the tire air pressure warranting settings on the TPMS.The dealer can do it.
They are allowed to turn off the seatbelt chime, it’s a function in the miscellaneous tabs of the bcm with their witech tool. I’m not guessing on this.I have doubts the dealer will turn off the seat belt chime being its a safety thing just like they are not allowed to change the tire air pressure warranting settings on the TPMS.
So weird that they can turn off a safety reminder but can not adjust tire pressure for the TPMSThey are allowed to turn off the seatbelt chime, it’s a function in the miscellaneous tabs of the bcm with their witech tool. I’m not guessing on this.
@Jimmy07 I did the seatbelt chime disable on my 2026 Limited Mega Cab with the digital display today and it worked like a charm with the buckle un-buckle method. So not sure if they changed anything on the 2026 but worked for me.Does your truck have the full digital instrument cluster?
The seatbelt trick doesn’t work on the digital cluster for 23-24 model years, so probably not on 25’s either.
The seatbelt trick does work on the cluster that has the two physical analog gauges, so anyone with a 2025 that chimes in and says it worked for them probably doesn’t have the full digital cluster.
