What is a good size tire for this truck ?Get some tires, sliders and get that thing off road!
Tire size is a deep subject.... First what type of terrain will you be driving.... A/T vs R/T vs MT tires.... What lift does your truck have.... What offset are the present wheels... 35" is a really good stopping point for so many reasons especially gear ratio.... I don't know if your power wagon has the 411 gears...if you're planning to regear to 5.++ Then you you might like the look of 37"... If your not trail running this rig (IMHO). Stop at 35s... Presently I have 33.4" tires.... And I am on rough forest roads to trails I am familiar with... I have a dedicated wheeler on 35s for the serious trails... A Titan swapped Xterra... Road noise and mpg are also things to think about and lastly if you need three peaks snow rating....I have the Falken wild peak a/t on my Ram and I have run KO3 AND KM3 and Toyo open Road R/T on my RedX DDOR...What is a good size tire for this truck ?
The weight rating of the tire is important as well ... Are you hauling heavy stuff?Tire size is a deep subject.... First what type of terrain will you be driving.... A/T vs R/T vs MT tires.... What lift does your truck have.... What offset are the present wheels... 35" is a really good stopping point for so many reasons especially gear ratio.... I don't know if your power wagon has the 411 gears...if you're planning to regear to 5.++ Then you you might like the look of 37"... If your not trail running this rig (IMHO). Stop at 35s... Presently I have 33.4" tires.... And I am on rough forest roads to trails I am familiar with... I have a dedicated wheeler on 35s for the serious trails... A Titan swapped Xterra... Road noise and mpg are also things to think about and lastly if you need three peaks snow rating....I have the Falken wild peak a/t on my Ram and I have run KO3 AND KM3 and Toyo open Road R/T on my RedX DDOR...
8-10K so I guess that’s as heavy as the PW can towThe weight rating of the tire is important as well ... Are you hauling heavy stuff?
OEM tire size. More aggressive tires if you want.What is a good size tire for this truck ?
