Thats a dag gum good question and i can't believe no body has yet to bring up. Good ????Just curious how the TPMS works after I rotate tires. Do you have to recalibrate something to my truck reads the right tire PSI.
Exactly how far is 200 feets?I installed six new TPMS modules with the new wheel set earlier this week.
They cloned the OEM ones so the truck wouldn't know they are new. So, it would be just like a tire rotation. Leaving the shop, all indicated 0 PSI. And after like 200 feets, they all came back on, with new pressure readings.
So a tire rotation should be really fast as the modules are already known. It is not like a full discovery of new modules which can take 15 minutes.
Humm... More than 20, less than 800.Exactly how far is 200 feets?![]()
::in before Rich burns the thread down to the ground.
For duallies, the inner duallys have to stay on the rear and inside, so they can only roate left/right. They use a different sensor so the system knows they are the inside wheel. If you have polished wheels then its best to just rotate all your wheels from left/right. if you have the steelles the outside can go front/back. most don't even bother cause the factory tires aren't worth extending their life.
P.s. you can always break down the tire and move it to where ever you want.
p.s.s. it's all in your owner's manual
I'll look that up. I remember the tire rotation diagram in the manual for dually. But do not remember the TPMS requirements in the manual.
