Got my trailer port relocated to the bed where it should have been to begin with. Also added a 2-way momentary switch for the electric tonneau so I don't have to worry about carrying a fob. This setup is so TIGHT, it makes the factory setup feel kind of trashy. These ports are snug and fit like they should. I also added 2 drain holes to the bottom of the factory plastic piece because when I first removed it, it was already full of dirt that had no way to escape. I imagine that given enough time, it'd rust through the bed.
I put a LOT of thought into this design, making it so that NO cutting of the bed metal is required, and with the intention of being able to mass-produce these. This prototype is 3D printed. I have material figured out so I can laser cut/weld this out of stainless steel. However, now that the 3D print is installed, it feels very sturdy to me.
If anyone would like to order one, please PM me or email
[email protected]
If there's minimal interest, I'm willing to 3D print more. If there's lots of interest, I will get things set up for laser cutting stainless.
There's plenty of camera cable to route this way, as you can see. You just have to remove a few zip ties upstream.
The only tools you'll need for this mod are a marker, dremel, drill, and deburring tool.
View attachment 87782View attachment 87778View attachment 87779View attachment 87780View attachment 87782
