2020 3500 Cargo Camera harness
OSMoses
So looking at adding the cargo camera to my new to me truck and don't like the mess that infotainment.com has for that. I would like to build out a custom harness like a number of people have done for the 4th gen ( Youtube Video of this:
Since the connectors are not the same for 5th gen I am trying to find the terminals/pins whatever they are called for the Suitomo 6098-8258 pins for both connector XY370A and XY441A (both female). Anyone know where to get some terminals to add to those connectors? Mopar only lists a full connector repair kit for $100.
Also anyone know of a source of CHMSL camera connector rather than buying a Gen 4 tailgate harness and modifying it? Could not find any repair kits for this one.
Okay so stumbled across this post right after I posted (after searching most of the week), which answers my question on the camera connector:
Quote from Jimmy07:
CHMSL camera connector outer housing- Yazaki 7289-0064
CHMSL camera connector inner body- Yazaki 7129-5503
CHMSL camera connector terminals (6)- Yazaki 7115-2482-02
Have continued to research this trying to find the right terminals. From visual observation I am currently thinking I would need these two:
0.64mm (025) 8100-3625
1.5mm (060) 8240-0279
These are mostly guessing by comparing sizes of existing pins. So far the best I can find if a minimum quantity of 100 for 8100-3625 and minimum quantity of 250 for 8240-0279
Got in a few of 8100-3625, they are not the right terminal but they are the right size, after more poking around it looks like I will need 8100-3619 for the 0.64mm one and 8240-0123 for the 1.5mm (slightly more educated guess.
Also looks like the connector part number that is in use on Sumitomo's site is 6098-7119
8100-3619 and 8240-0123 are not correct either. For the 1.5mm on I have ordered a Molex MX150 and a Yazaki terminal that are similar to try. Searching for something similar for the 0.64mm connector but not finding anything just right so far
The Molex MX150 terminal is a direct match to what was already in the connector. Still have not found anything similar to the 0.64mm terminal. Will probably just end of modifying the 8100-3625 terminals that I already have. Hope to have my new CHMSL (with cameras) in Friday
Where were you able to locate and aquire the camera or the whole third brake light assembly from?
The 8100-3625 worked great once the flag was clipped (part circled in red is what I am calling a flag). I had ordered the wire recommended in the other video which turned out to be solid core, so after a number of breaks later I have better wire ordered (and a few more terminals). Though for the moment it is hobbled together barely enough to verify the camera is working and that I evidently got some dirt in the camera hole one of the times I had the camera out.
