You know your right, thought I was on the other post. Thanks for setting me straight.You know this thread isn’t about DEF/SCR, right?
There is nothing anyone other than the engineers can do anything about it. It is what it is.
Wrong TSB, see my earlier post for the correct one. If you are implying that because one TSB didn't fix some issue, all TSB's are worthless, I'd disagree. I do wish this one was a recall and not a TSB though.
Curious if this was done under warranty would Stelantis allow the dealer to do that?Has anyone that has had a DPF replaced for excessive regens had the it cut open to see if its actually loaded with soot?
I do think it would be an interesting answer, full of variables though, like when was the last regen before it was taken out.
Have you read the TSB? They know very well which trucks to recall.I never implied all TSBs are worthless...thats silly.
What would a recall change vs the TSB? They don't really know what to recall...considering the trucks have all the EPA required equipment, granted not working as designed completely, is probably why its a TSB not a recall is my guess...could be wrong.
{sigh} No, what I meant, they have no idea how to fix it. They probably wont recall something with out some sort of "fix", may have to wait on the parts etc however if they are not readily available.Have you read the TSB? They know very well which trucks to recall.
As far as what it would change, it would make my truck eligible for a replacement. Since I pretty much only use my truck for towing, I may not see this issue come up until the warranty and TSB have run out. I just turned over to 20K miles, coming up on 3 years. Replacing a DPF is pretty darn expensive, from what folks have posted. I'd like to not have to eat that. If they suspect all those trucks may have a defective part, they should recall and replace them all, IMO.
So you think they'd issue a TSB saying replace the DPF, but they have "no idea how to fix it"?{sigh} No, what I meant, they have no idea how to fix it. They probably wont recall something with out some sort of "fix", may have to wait on the parts etc however if they are not readily available.
True, and I may check into that, if the time ever comes.You don't have to always have to replace a DPF, they can be professionally cleaned and restored/recore to new for $500 or less. (like this place https://redeyeradiator.com/)
In this case it would, as my truck is one that the TSB applies to. Assuming the recall would be for the same lot of VIN's.A recall does not make your truck automatically up for replacement.
I've done a buy back. But my truck is fine, as I pretty much only tow with it. I'm worried about down the road when it's 10-15 years old. Yes, I keep my trucks that long. RAM knows the DPF is, at the very least, suspect in my truck. They should replace it, IMO.You could do a buy back now if you really feel you have a problematic truck. A buy back is generally not complicated unless you go the lemon law route.
Maybe they were replaced from the same bad lot of DPF's.Well, I think it's a "best" guess since for some, it has not fixed it. In fact, between this and other forums it seems replacing the DPF has not been very successful.
Post TSB, maybe.I would think they would specific lot numbers or even a part number change for the new DPF,
A lot of folks don't start having issues until they start to roll the miles on. So it will remain a worry. I could bury my head in the sand and hope for the best, but I am a guy that takes a lot of time and effort to take very good care of all of my stuff. So burying my head is not really something I do.I would say you can just enjoy that truck if its not having issues.
Post TSB, maybe.
This makes no sense, at least to me. It doesn't keep me up at night, but it's worth keeping an eye on/worrying about. It's not hard to keep track of it, and yes, I have a spreasheet for it. Maybe you'd feel differently if your truck was one of the ones listed in the TSB.Jeb,
All I will say on this subject is you cant worry about things you have no control over. Drive it and maintain per the manual.
sstoner911:I owned a 2022, never had any issues with it other than some Uconnect issues -
Just because your truck year/build dates are on a TSB doesn't mean it will have issues. Honestly if it were me and I had to choose between a spreadsheet or spending 6K to eliminate the issue completely.
I am spending 6K, I have enough spreadsheets at work I don't want one for my truck.
sstoner911:
I do agree with some points you make in your replies, with the exception of your last sentence, we shouldn't have to pay an extra 6 grand or any additional amount of money for that matter to rectify or "fix" something that should be a non issue. Also I feel it Shouldn't be a weight or concern either, yes these are mechanical beasts with a million moving firing electrical parts and things break or go bad sure enough.
With that said I have a question for opinion, was the whole (in general) DPF def regeneration system rushed to meet guidelines demand and keep product being produced or is it more a work in progress to continually improve.
But if your truck is running as designed but the DPF is causing some concerns, OCD territory, just delete the darn thing.
