Jgouldski
I have a very odd situation going on with my rear brake/turn lights. I was testing all the lights on the truck with AlfaOBD to make sure they all work after I made some changes to settings. Now my engine light is on and it's throwing codes for each of the 4 turn lights, front and back. Here's all the current symptoms:
- All 4 turn lamp control codes are active.
- Turning the turn lights on with the blinker switch goes into rapid flash mode like it's detecting a bulb that's out. Front turn signals and side mirror light turn signals all work, rears do not.
- Hazard light switch does not flash them rapidly, but only the same lights as above work.
Now, with AlfaOBD commands, here is what works/doesn't work:
- Both front turn signals work.
- Rear left stop/turn light and rear right stop/turn light both work.
- Rear left turn light and rear right turn light both work.
- Rear left parking lights command works, but rear right parking lights command does not (same bulb as stop light, which does work)
Anyone got any ideas for what I can check?
