I started to notice last week that the truck was sluggish to start, especially in the morning when temps were cooler.
The truck is a '22 CTD and I've read on the forums in the past that these OEM batteries only last about 3yrs. Using Project Farm's suggested battery tester, I bought the Ancel BA101 and ran the "in vehicle" test. It came back as good but noticed CCA were measured at 930. This well exceeds the 730 CCA of a single battery. I assume this is because they're in parallel and I'd need to isolate each battery by disconnecting the negative terminal.
However, if I plan to replace both batteries as suggested, can I just double the CCA (1460) in the tester to get a true result? Doing this does result in "Replace Battery" but I'm unsure of the accuracy.
Also, FWIW, I noticed a lot of corrosive build up on the passenger-side negative terminal so I suspect this is the bad battery (assuming one is bad).
Thanks.
Thanks.
