Not really... you can trigger a stationary active regen with Alfa or JScan (if/when they add support to the 2025s) I believe but there's nothing in the vehicle to enable this directly. I'm hoping regens on the 25 are simply something that will fall to the background and be a non issue / no driver intervention required. We shall see.Some vehicles have a way to manually trigger a cycle - to run when it is convenient like during a longer drive. Is there any option to do it this way ?
Not really... you can trigger a stationary active regen with Alfa or JScan (if/when they support to the 2025s) I believe but there's nothing in the vehicle to enable this directly. I'm hoping regens on the 25 are simply something that will fall to the background and be a non issue / no driver intervention required. We shall see.
There are 3 different EViC’s for 23+ trucks.i had the larger screen in my 21 and it showed it as well. my idash shows it in regen as well. as much as my truck has in it tech wise, why id didnt have the bigger screen dash is odd but what ever lol
Very strange, I pull my #7000 TT and not more than about 30 minutes my DPF gauge jumps down to zero and says there. Mines a ‘23 so the regeneration strategy is surely different, that coupled with the changes to the exhaust non towing passive regeneration will no doubt behave differently but not going down to zero and continuing to build while towing is strange. So, you’re saying while towing the DPF gauge continued to climb?the next 600 miles were all towing our ~8500 lb travel trailer at 60 - 65 mph, and the DPF steadily went up from 0% to 30% at the end of the trip.
Correct. I don't have an iDash or any other way to monitor EGTs, so I can't comment on that. The original post in this thread indicates similar behavior when unloaded (up to 30% after 700 miles of highway speeds), but I haven't seen much feedback from others while towing with their '25s. Towing was in T/H mode and mostly 8th gear and 1500 rpm, with some time in 7th for spots with more hills. I could have locked out 8th but I don't think that improves temperatures or soot load.Very strange, I pull my #7000 TT and not more than about 30 minutes my DPF gauge jumps down to zero and says there. Mines a ‘23 so the regeneration strategy is surely different, that coupled with the changes to the exhaust non towing passive regeneration will no doubt behave differently but not going down to zero and continuing to build while towing is strange. So, you’re saying while towing the DPF gauge continued to climb?
My 3 regens have come at 867mi, 568mi, and 386mi. I'm mostly unloaded on a 35 mi straight shot to work and travel 75 to 80mph. The last two regens happened with only 10% on DPF gauge. My CTS3 that I had on my 22' killed my batteries and I had to take it off so I don't know what temps are doing.
I think you might be right. I haven’t had a chance to drive one yet, but I’ve seen a few pictures posted. Looks like the instrument cluster guage now shows movement in 10% increments maybe? That would be a big change compared to 24 and older. We may now be getting better data that would parallel the PID information rather than only showing the last few incremental climbs before a soot based regen kicks on.There is also a strong possibility that the dash has been reprogrammed, especially since most 25 owners seem to be reporting more movement on the DPF gauge.
I wasn't expecting it, but there's definitely a low end grumble when in regen. Sounds like light exhaust braking, but only when in gear and most noticable at idle or low speedWith the 7th injector, I wouldn't expect the engine to be working harder (raising EGT) to avoid or assist regen.
