Shocktrooper392
Hey guys, so I got the Baja Designs A-Pillar Sport Ram XL light kit way back when CJC had their Black Friday sale going.
I installed them a few months ago and they worked great! Took a little while to adjust the lights to where I wanted them, but otherwise awesome!
A couple weeks ago I noticed one night at my girlfriends house that they were kinda flickering when the truck was off. I checked all the connectors, they were all good, checked the switch and came to figure out the switch wasn't fully getting good contact when clicking to OFF.
Pulled the switch just a hair out of the trim panel it's mounted to and left it alone. No more flicker.
So alright the switch needs to be mounted better. I got a different switch with a mounting collar/bracket that should give it more threshold against the trim panel to where it can completely click OFF for good contact.
Well go to change the switch out yesterday and new switch will light up red in the ON position but the BD lights won't turn on.
Checked the fuse, fuse is good. All my connections are good. Put the old switch back on and same outcome, old switch lights up red but the BD lights won't turn on.
So the switch is getting power but I guess the lights aren't.
Is it possible the BD lights got burned out by the switch? Is it possible I blew the relay?
One thing I haven't tried is disconnecting the power supply wire & ground wire from the battery to try to "reset" the lights, but I wouldn't think that would change anything?
I don't have a power probe but I'd guess that'd be my best bet? Just curious if anyone else has had issued with the BD harnesses they supply with the A-Pillar lights.
