2019 2500 6.4 laramie coil sprung rear suspension. Bought it a year ago and have put about 17,000 miles on it with 35,000 miles on it now. Couple questions of things I notice now:
The brake pedal feels like old 2 ton truck brakes. Meaning, old 2 ton truck brakes you can pump a couple times to get a firmer feel on the pedal. Well, my truck can do the same thing. Initial push goes pretty far to the floor. Then if I push the pedal again, the pedal feels firmer and doesn't go nearly as far to the floor. Anybody else's do that? I"m not too concerned with this as much as the next.
Secondly, maybe this is related to the first, when slowing down i can feel the whole truck lurch like it has warped rotors. I know when I've had warped rotors in the past on other vehicles, I could feel the pulsation through the pedal. I don't feel any pulsation through the pedal in this instance. That leads me to believe that the front rotors are ok since that's where most the braking power comes from, and possibly the rear rotors are warped and maybe the pads are lightly grabbing the warped part. Will i feel pedal pulsation if the rear rotors are warped?
Thinking about pulling the rear rotors and having them turned. I suppose I could have a caliper hanging up too.
Is there any other component on a coil sprung rear suspension that could be wore out causing this? The shock absorber above the axle?
Thanks for any ideas you have.
