dieselscout80
My thermostat was setting off a service engine code for an irrational thermostat, so I swapped it out.
The radiator drain is a yellow wing nut and 5/16” hose fits on the drain. I drained just less than 2 gallons from the radiator and it kept me from spilling much when the thermostat was removed.
I undid my air filter box lid and held it up with a tarp strap.
There are two bolts (13mm socket) and I used a couple long extension the one with the socket was a wobble extension. I left the hose attached to pull the thermostat off. There is a marked link on hose that lines up with the tab on the thermostat.
I topped off the overflow tank and burped it by squeezing the lower radiator hose.
It is not a bad job but the electrical connector on it is not easy to disconnect and reconnect.
