Those are all good ones. We should just design our own build and the masses will comeSeat belts that retract- the springs on mine are weak
Taller GM/Ford style mirrors
Ability to leave Tow Haul and exhaust brake on all the time
8 speed Aisin with an additional gear between current 1-2 and another between current 2-3
Telescoping steering wheel
Off road package avail for 3500
Telescoping steering wheel would be VERY NICE (1500's already have this, eh?)
And power tow/haul settings for the mirrors, like on my Ford. The Ram ones you have to manually flip from horizontal to vertical. Driver's side is ~OK, but passenger side if there is no passenger reminds me of the good ole days when you had to manually adjust the side view mirrors.Taller GM/Ford style mirrors
Everyone needs one of those, or both, that sounds better. Ok losing focus boz & rich, get back on track. Bottom line these are great trucks, but there is still allot of room for improvement. I'm sure allot of these things will be corrected over time but they really dropped the ball on not having the most advanced technology. That would probably be my number one PICK as it covers several issues.Rich, you forgot the secretary/ nurse to hold...........it for you(your beverage).
Great list!1: brighter puddle lights
2: more led bed lights
3: camera screen that will stay on with an acceptance button
4: side camera with turn signals
5: no dead pedal
6: better turn radius
7: memory spot mirrors
8: 12" uconnect health report
9: auto memory high vented seat
10: higher end more capable computer technology
11: more advanced send and go features
12: RV route choice with over heighth restrictions
13: rest area locations on interstates
14: more accurate regen gauge
15: cp3, cp3, cp3
16: steering wheel button for cameras
17: air condition should not go off while putting in destination
18: more fuel tank options like on cab snd chassis
19: standard 2 yr ram care
20: more adjustment in airbag functionality
honestly, I'm sure ill think of some more changes I would make to my truck if I was at the plant building my own, as I believe a 85 k pick up truck should be the the cadi of pu trucks with everything high end where your left not wanting anything more. All these things and I'm still extremely happy with my purchase, but it can always be better.
Ability to see what gear I am in without having to activate the limiter.
That would have been me.Can be done with AlphaOBD. There's a thread here on it.
I think after it was found, someone made a stink with Ramcares about this being in the user manual but not enabled in the trucks. However, I wouldn't hold your breath that it will show up.
This has been bugging me for a while. Indeed, I would like a lot more "remember the last setting", including vented/heated seats as well as exhaust brake (mentioned by many in other threads). I note that for the vented seats, you can have "auto-on driver heated/ventilated seats and steering wheel" in Uconnect, but it a) only does the driver, and b) puts the seat in low, which, as others have indicated, does next to nothing. If I've got the seats on now, I will most likely need them on the next time I start the truck. I at least discovered that I can put them on the menu bar, so that helps a bit, since they are now just a single touch away.9: auto memory high vented seat
