Not flywheel driven - the medium duty ISB engines are rear geartrain, so accessories are driven from a gear on the rear that's just ahead of the rear flywheel mounting surface/rear seal sealing surface of the crank. On the current 6.7L, the only gear driven component in the front is the lube pump.
For the 7.2L, even the above has changed; the engine's becoming more of a baby ISX. And like
@mbarber84 mentioned, it's supposedly the same height or lower as the current 6.7L iteration.
It's fun comparing the 6.7L Octane to this...a few differences on the bottom end, but up top it's a whole 'nother story.
