Trying to get my Fox shocks installed, and no matter what I do I can’t get the lower bushing to line up with the mount enough to get the bolt through!
I’ve tried no weight on the suspension, some weight, most of the weight, and even turning the caster adjusters to try to change the angle of the axle a bit, all to no relief.
I’ve also tried tapping the bolt through with a rubber mallet (since the bolt has a slight taper/point at the end) but it’s not close enough for that to work.
What am I doing wrong here?
