Water dripping from visor
PhishWagon
PNW
Started getting a random drip from drivers side visor where its screwed in to the ceiling. Anyone else have this issue? We get plenty of rain up here in PNW but this just started happening. Wondering how much is up in there but afraid to start pulling stuff apart. No loose lights or antennas on the roof. Any suggestions?
3rd brake light leaking is way more common, aftermarket cablights leak not usually oems
I had leaking from my left side grab handle and they replaced all the cab lights now it is gone.
Check the cab light gaskets.
You may have a satellite radio antenna in the area above the drivers side visor that could have a bad seal. Not to be confused with the shark fin that's on the passenger side.
Phishwagon, did you figure it out? My 2019 2500 just started dripping water in that area. I think maybe the antenna seal is cracked. Looked at parts diagram online and it doesn’t even show a gasket or seal that’s separate. Tempted to run a bead of some sort of silicone around it.
It’s worth trying. I plan to take it into the dealership to replace all the cab lights. Just haven’t had the time. In the meantime, the leak stopped even after a couple of car washes.
I had a leak from the drivers grab handle. I noticed the driver door seal was a bit out of place, I pushed it all back in/straightened it out and haven’t noticed a leak since.
If support is required while your vehicle is at the dealer, please let us know! We are more than willing to apply support where able in order to find a resolution to this.
Chris,
Ram Cares
Just had this EXACT leak happen to me today. Did you ever find the cause? Would love to find out where to look first. Thanks!
My shark fin was leaking. No issues ever since they replaced it. Been through a few car washes since.
My shark fan was leaking. No issues ever since they replaced it.
Thanks!
Gasket not put on in Mexico plant. Mine was fixed last week .
Great. I could see that the gasket on mine had a crack in it probably from shrinking. I ran a small bead of silicone sealer around it and it fixed the problem. Mine is a 2019 2500.
I had water running down the drivers side grab handle, they replaced all the cab lights. Mine is a 2020 and I'm betting it's a covid era screw up with the seals on the lights... poor installation????
