My 5.7 R/T Durango will go into mds unless you hit the “eco off” button in the center stack. Once pressed it stays off until it’s pressed again. This includes after shutdowns, etc. other options on my specific model are track and sport modes will also deactivate it.Not well-versed with the 6.4 gas engines, but I believe (someone correct me if I’m wrong) you can inhibit the MDS by simply putting the truck into ERS mode. Its a work-around. AFAIK, all the current 5.7 and 6.4 hemi engines come with MDS and there’s no direct option on the truck to manually shut it off or disable it, aside from the workaround I mentioned.
It is my understanding that ECO mode and MDS are independent functions. ECO mode changes the shift schedule in the transmission. MDS deactivates cylinders when cruising in certain conditions. Thus engaging or disengaging ECO mode will not have an effect on the MDS system. As far as I know, the only work-around is using ERS mode or Tow / Haul to trick the vehicle into shutting MDS off.My 5.7 R/T Durango will go into mds unless you hit the “eco off” button in the center stack. Once pressed it stays off until it’s pressed again. This includes after shutdowns, etc. other options on my specific model are track and sport modes will also deactivate it.
Yep, I keep it turned off on my R/T as wellMy 5.7 R/T Durango will go into mds unless you hit the “eco off” button in the center stack. Once pressed it stays off until it’s pressed again. This includes after shutdowns, etc. other options on my specific model are track and sport modes will also deactivate it.
Eco deactivates 4 cylinders. It makes a noticeable tone change when parameters are right for it to be in eco and when it’s lagging behind accelerating and the mds kicks out it sounds like a normal Hemi again.It is my understanding that ECO mode and MDS are independent functions. ECO mode changes the shift schedule in the transmission. MDS deactivates cylinders when cruising in certain conditions. Thus engaging or disengaging ECO mode will not have an effect on the MDS system. As far as I know, the only work-around is using ERS mode or Tow / Haul to trick the vehicle into shutting MDS off.
Again, I’m really not well-versed in the gas engines so if I’m wrong I would appreciate a correction!
I’m not aware of any 6.4 BGE’s that did not come with MDS.I tune mds on and off with hptuners for people vehicles, but more or less was interested if any ram factory models were not using it.
like back in ~2011, when ram 1500 + 2500's both were using 5.7's, the 1500 had ads equipment but the 2500's did not. same 5.7 block. it was more a curiosity thing if any of the HD models were not shipping with MDS.
The challenger scat packs (6.4) manuals do not have MDS.is there a trim or series with a 6.4 that does NOT use MDS??
like say a 4500 cab & chassis? are those still equipped with MDS?
do POWER wagons have MDS?
Hello, I work at ZF and was involved in the Powerline development for 2025.is there a trim or series with a 6.4 that does NOT use MDS??
The 6.4 Hemi does not use MDS on the Chassis Cabs equipped with a Powerline transmission.
The new 2025 2500’s no longer have MDS, you can look it up under the Ram trucks build
2025 techauthority service manual still addresses MDS, and the schematics still show MDS solenoids for cylinders 1, 4, 6, and 7.The new 2025 2500’s no longer have MDS, you can look it up under the Ram trucks build
No. Either put it into tow/haul, or use the gear limit switch to limit the transmission to 8, and MDS will be deactivated.Is there anyway to deactivate MDS using AlfaOBD?
