Yeah I saw that typo too.Haha, they said aluminate, they probably meant illuminate but aluminate is a word. Darn spell checkers...
Or at least I hope it’s a typo lol
Jeez that is a lot of elbow grease to get all that off. I have an appointment with the dealer when I get home hopefully they will not have a problem getting the new part numberMine was completely soaked like that as well.
After using four cans of brake cleaner clean up, & A little bit. Of time, We found the rear output shaft seal was the culprit.
I replaced it myself with a new seal under the old part number. After about a month it started leaking again.
The local dealer Finally got the new seals in under the new part number and haven't had any problems since.
I may have been wrong about the new part number. But here is the invoice I found. Hope it helps.That would be awesome thanks!
Awesome I’ll clean it off this evening and see if it returns as for the seal I’m just going to do it at my shop as my dealer is painfully inconsistent and super slow!I was told the same, rear main seal leaking. turns out it is residue from an anti corrosion. someone posted something in here about it from Mopar awhile back. I sprayed it down with brake cleaner & no more rear main leak.
As for the shaft leaking, join the club![]()
Hey thanks for the tip I’m going to tow with it this weekend.It’s probably going to come back at least once or twice do some heavy towing and get the motor hot and trans hot, it’ll melt everything down. I had it on mine a couple times after some heavy tows, cleaned real good with brake clean and hasn’t returned.
Indeed.Crazy times
I hope urs isn’t a main seal leak!I had the front wheels off my truck yesterday installing the level kit and got a good look at the bell housing area, and I see what I hope is only the faux main leak (the goo applied at the factory that looks like a main leak). Its kinda covered in road grime now and it doesn't look fresh, but I cleaned it up a bit and Ill keep an eye on it. The shaft seal does not appear to be leaking at all.... yet.
Uh, thanks for that. I hope the same. I have a feeling, if its a main leak, it would look more "fresh" and I probably would have seen some drips under the truck by now.I hope urs isn’t a main seal leak!
Agreed or at least you would think so right? I haven’t checked mine yet just did a big towing trip. But I have also read on some other posts if you use a black light or uv light it should glow if it’s the packing goo.Uh, thanks for that. I hope the same. I have a feeling, if its a main leak, it would look more "fresh" and I probably would have seen some drips under the truck by now.
Dang sorry to hear that!Well update in mine. I need a new torque converter, I have the drive shaft seal leaking, and the transfer case seal leaking. Lord only knows when the parts will come in
