NO LONGER AVAILABLE: Looking for a Part Number? Must provide VIN (only up to model year 2020 at this time)
Status
Not open for further replies.
Attached is the switch bank for your VIN. Also, a breakdown of the different switches is here and information on the console pictured can be found here. If you need more info than what's in that thread, give me a VIN that has the part you're looking for and I can check it out.
I found a Ram part number-68476026ab. My vin is 3c63rrglxkg578491. is this compatable for my 2019 Tradesman 3500?
Looking for the parts needed to add heated/ventilated seats, just fronts for now. Looks like it is different foam and possibly different seat covers with the ventilated option, and from what I understand it is only the "bag" needed for both heat & ventilation (4 total, 2 for each seat)? Also need a total of 4 blowers, 2 for each seat. And a module for each maybe?
I believe this truck has both options: 3C63RRJL5KG515663
See attached.
Hi,
My vin is 3C63R3EL6LG215297. I'm looking for the part number for the exhaust filter for my truck.
Thanks.
Jeff
Hi,
Thanks.
Jeff
I'm thinking it's mislabeled 'Converter, Catalytic Selective Reduction' at callout#16 (68267075AE), since the SCR is #7 (68296341AE), also labeled as "Converter, Catalytic Selective Reduction'?
Thanks a lot for looking it up!! so you think it should be #7? 68296341AE? it looks like it. when I google that part number mopar.com says under description that it's the diesel particulate filter.
How about the rear anti sway bar and bushings and clamps, for VIN 3C6TR5EJ8KG528652 ? TIA
I don't want to tell you the wrong thing. My AllDataDIY subscription lapsed, otherwise I'd check there for you to confirm. I'd call a dealer to verify before ordering anything to be sure.
Rear suspension components attached.
Can you provide me with the part numbers for the rear seat latch plastic insulator near the top of the seat.
3C6UR5DJ7LG223246
3C6UR5DJ7LG223246
Attached are all of the items I found associated with the rear seats...
My vin is 3C63R3EL6LG215297. I'm looking this part on the driver's side fender behind the rear wheel. I hit a piece of retread on the freeway and it was nice enough to do this and bust the folding step...dang it!! Thanks jeff.
Ps thanks for the exhaust filter info. Got a new one installed!
My computer decided to stop working so I'm waiting on parts to get it up and going. Not sure how long it will be out of commission as I'm trying to turn this into a positive and upgrade it while I have it apart. As soon as I get it back going, I'll get this for you.
Sorry for the delay @LBC_Jeff ...here ya go.
I have been searching everywhere for this, found it on a 2019 RAM 2500 3C6UR5NJ0KG593063
Looking for the part numbers for the instrument panel lower 115v power outlet and mounting plate.
Also looking for the rear center console mini-usb (type c) usb ports and 115v power outlet and mounting.
There should also be a cable that connects the instrument panel lower usb ports to the rear usb ports.
Thank you
Raul
Status
