ErikTheRed
I just spent the past hour searching for info on tire upsizing, found some helpful stuff but I'm looking for specific answers to my specific questions....
1- Fit. I have a 2024 Bighorn 3500 SRW, stock tires are Trashfarce AT 275-70-18. I want to upsize to 295-70-18. I will use the Bighorn wheels and keep everything stock, I do not plan to change the springs or add a level kit. Will there be any fit or turning/rubbing issues?
2- Going from the 275-70-18 to a 295-70-18, according to online tire size calculators, at 70 mph, will result in about a 2 mph diff in speedo displayed vs actual (speedo shows 70, actually going 72). I can live with that, if the calculator is accurate. What have you fellas experienced? I've read that JScan can adjust the speedo, but does JScan work on a 2024?
3- What about the TPMS? Based on what I've read, if I'm understanding correctly, the upsized 295 tire's inflation pressures are within the parameters of the TPMS so there shouldn't be any issues. Amiright?
4- Any performance changes? I assume the overall ride will probably be a little better, but what about towing? Changing the tire size will change the final drive ratio, but is it enough to even matter? I'd think not. How was your fuel economy affected? Probably not a noteworthy difference there either. Any noticeable shift point concerns with the Aisin?
5- Without looking, I assume my spare is the same stock 275-70-18 size. I should probably order a 5th tire to replace the spare too, yeah?
Thanks for any info, people! I'll wait for a few replies so I can feel better before putting the credit card to work.
