2020 3500 6.7 grid heater wire location
apex32
Hi there, just brought a 2020 3500 home and want to disconnect the grid heater at the battery. My passenger battery terminal looks different than the posts I’ve found to disconnect, all have been a little older.
Anyone have a good photo of where this is on a 2020? I checked the post and it’s tight and I want to not worry about it and I’m in Texas anyways. Don’t really want a banks intake.
Thanks
Adding a photo - is it still the middle of the 3? Just looks different than the posts I’ve seen which were a small basic eyelet on the wire.
I would trace the wire to the relay. Mine is the bottom one in your photo if I remember correctly but I can check tomorrow. But you should be able to follow the wire under and over to the relay.
That’s what I was thinking just need to get in there.
Yup its the bottom one not the middle, assuming the solenoid under the intake is the correct one. Thanks
