Looks like TFL states that there is a rumor that Cummins will be building a 7.2L diesel for a variety of reasons. Possibly for the 27 model year, but maybe sooner... By my calculations if todays HO 6.7 was swapped with the larger 7.2L with the same volumetric efficiency (same hp / tq per L). Swapping to a 7.2L would result in a 450hp / 1155ft/lbs. So with some tweaking, better airflow the engine probably will match or exceed the power output of the 6.7 ford. But another way to read into this (my speculation), is that the '25 cummins 6.7 may not see much of a power change, since they are working on a larger displacement engine.
