BadKarma
Normal oil change today, was also going to change differential fluid as well. Instead of getting my step stool I decided to stand on the ranch hand grill guard got 3 quarts in everything was all right. Dripped a little bit on the ranch hand and thought to myself no worries. Went for the fourth quart and went to go pour the oil in and slipped. Spilt about a half a quart all over the motor. So I washed the engine bay with some dawn soap and hot water. First pass, I let it dry for a little bit with some low air pressure, then started the truck and instantly had a squeal from the serpentine belt. Turned it off, washed it again, but this time with the pressure washer and foam canon. Let it run for about 30 minutes and it seemed to be fine no more squeal and no more smoke from burning oil. I swear sometimes I make the easiest jobs the hardest.
