*Breaking News* 2025 Orders from MARK DODGE **
It seems that there is no way to get the CHMSL bed camera (LPD) or dual zone auto climate control (HAF) without the 12” screen. Is there a way around this? I’m looking at a 3500 SRW Lvl 2 Big Horn and was really excited that it still had the smaller screen. FWIW, I think the bed camera should be part of 5th wheel/GN prep group.
You are correct, at least currently.
@AnthonyRI
On the website builder, I've discovered that you can add both OffRoad Package and Air Suspension. Can you confirm that this is accurate? I'm surprised as I'm certain that wasn't possible to combine in prior years.
Thanks!
THE GOOD NEWS IS THAT SRW AIR SUSPENSION APPEARS IN CODE GUIDES - will do a deeper look over next few days, just saw it populate tonight when I was setting up an order!!!
EDIT - Spoke too soon
Now things have settled in.... and it appears that simply the air suspension was removed from MAX tow and listed separately, but when I hit air suspension it requires dually and max tow.
Will continue to monitor this, but appears my excitement may have been misplaced.
Updated code guides added.
I put an order in on December 9th for a Limited Longhorn Mega Cab and it is still in order confirmed status.
For a previous truck, I put an order in for a Limited as soon as orders opened in July that year, but RAM held the order until they announced the launch in October. You should probably count the days beginning January 7th…
What is the estimated turnaround time for a Laramie 3500 srw?
Too soon to tell, but they have started production. Orders opened in November, but production started in January, so it's hard to tell the staging between order to build if placed once the machine is moving.
ALSO sometimes they hold vehicles in containment at very first production, for extra testing/verification etc before release. So it won't be until later in year when we can REALLY see a track record an average data points.
All that being said, they are building!
Does anyone know when the Ram 3500 or 2500 regular cab bighorn 4x4 with a gas engine will be available to order?
@AnthonyRI Hey Anthony, do you know if it is possible to delete the GLOBAL TELEMATICS BOX MODULE from a build on the 3500's? I am purchasing mine outright, so I don't want them tracking me. lol
Any details on the onboard power system/2.2 inverter, other than late availability?
This is actually wild info ! Thank you for sharing an inside view of operations :)
You don’t by chance know what the dates they opened up each modem for the 2024 run was? For the gassers anyways. I don’t want to keep pestering you about the rebels, so im hoping maybe last years run might be an indication of what I can expect for a wait for this years. I’d expect it to be soon with them opening stuff up at the beginning of January.
My apologies for being a pain, I’m just in desperate need of a truck for work and only things left anywhere near me for 2024s are 150k optioned up
I wonder if the wiring will still be in the wiring harness to back of the truck of all the trim levels that it is suppose to be available on so you could add it later.
