brandon_mchenry-mt
2018 Tradesman 2500 6.7l Cummins 4x4, 86k miles
I am having this same issue, after a cold night or extended sit in cold weather “click” no start. Occasionally it will start after 5-6 attempts.
If I remove the starter solenoid relay and jump the pins using a paperclip, it turns right over and starts up. No struggles/rough warmup as if the block was cold, indicating the block heater is functioning.
Last year the engine block heater and one battery went bad, I replaced both batteries and the engine block heater. Additionally, I replaced the starter solenoid relay thinking it might be the culprit, no joy.
Every once in a while i do get the ETC warning light but turning the truck off letting it sit for 30 seconds (doing nothing else) and restarting usually corrects that.
Things I know it is NOT:
Starter
Solenoid
Solenoid relay
batteries
block heater
grid heater
Any other ideas?
Starter
Solenoid
Solenoid relay
batteries
block heater
grid heater
Any other ideas?
