CdnHO
One thing I have learned since owning this truck for almost four years now. A lot of stuff about it make no sense. Sort of like being married to the damn thing.
If the hour/idle meter is so incredibly inaccurate, makes me question all the other gauges and meters on this jalopy that are run by the same computer....
How many hours were on it when you picked it up?But.... 151 hrs on a truck with only 3800 miles on the odo? The only way I can figure thats even possible is if the truck has spent it's entire life so far (since July 2024) creeping around @ 25 mph. I'm the only owner and I can assure you, that isn't even close to the case. Ive used the truck almost exclusively on longer highway trips, very little in-town stuff and I intentionally keep idle time to a minimum. I dont use remote start because if I do, I can't idle it up using the cruise buttons. Something is definitely amiss with the hour meter.
Hours I really dont know, I never even thought to look.... or even that I could look. But it had 160 miles, and I probably put 20 of those on it myself during the test drive. Also I know the dealership I bought it from has two locations, one in Reno and one in Fernley, and the truck had been at both dealerships at some point so they had to drive it from one to the other at least once.How many hours were on it when you picked it up?
Well I guess I can't argue with that possibility. But man that sure seems like an awful lot. So, note to those looking to buy a new truck-- CHECK THE HOUR METER, NOT JUST THE ODOMETER, BEFORE YOU BUY!I'd put money on an accurate hour meter with lots of dealership idle time, they like to do that.
I really questioned mine also when the truck was newer and nothing has changed. Some of these trucks seem to count as expected, others not so much. I have a not so much truck and maybe you do too. I do not use the truck in town. It is basically exclusively long distance towing with long periods of no use in between. Typically will hook up the TT and tow 2 to 6 hours to a campground at mostly highway speeds and then repeat the next day. My idle hours have been crazy high since the start. Right now at just under 15,000 miles, Idle 102, Drive 304. Obviously incorrect but what can you do. I even use the high idle up as much as I can so almost no idle at lowest rpms. Only concern I have is that I have seen some people say when they have an issue with the emission system, dealer will tell them it is because their idle hours are too high, which in a case like mine, might look like it, but is not.Ive used the truck almost exclusively on longer highway trips, very little in-town stuff and I intentionally keep idle time to a minimum. I dont use remote start because if I do, I can't idle it up using the cruise buttons.
Yeah that seems off. As I just posted my idle hours are high like yours but now I am at 15,000 miles with 406 total hours. If you extrapolate your 3800 miles out to my 15,000, you will have over 600 hours on the truck compared to my 400. Could just be because I am at higher speeds cause of towing almost exclusively, but still unless you spend your driving life at red lights it does not make sense to me. And you describe your driving as very close to my style anyway so weird for sure.My meter shows 150 total hours, and my idle hours are at 50. my 2024 truck with only 3800 miles
Absolutely, especially since FCA could try to deny warranty with high idle time. (Cummins states anything over 16.6% idle time is excessive).
I was frustrated with the 50% idle time when I pickup up my truck, but I’ve gotten it back down to right at 11%.
Mine is still at 25% idle time even with my driving style. Maybe the % has come down a bit the past couple of years but not as much as yours. Not sure how you could get yours from 50% to 11% unless you have 100,000 more miles on the truck than I do on mine.
Campground time has always surprised me with how quick it adds idle hours, even on my 2018 that I sold at 8.1% idle time. It only had an average speed of 34.3.
I’ll bet if you monitor it closely it will add up quicker than you think. Startup, cool down, less than 3-5 mph maneuvering, trailer hitching and un-hitching, etc.
No.Since posting this,
“I upgraded to an Evic 7 and the hour meter was about 1/2 of the engine hours. Does AlfaOBD or JSCAN have the ability to set the hour meter? If so, can anyone link or post the procedure? Thanks!
no one has addressed my question, can the idle hours be adjusted with AlfaOBD…how about JScan? Thanks
